moteur AEROMOMENTUM AM-15
MessagePosté le: Sam 28 Juin - 00:16 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
intéressent moteur....
http://www.aeromomentum.com/am15.html
full system price is just $8995
The AM15 engine is a 1.5 liter 4 cylider automotive engine of 117 hp converted to aircraft use. This engine is comparable in power and/or weight to the Rotax 912 and Continental O-200. Built in both upright or low profile slant versions. The upright versions are mostly used in trikes, light twins and replica aircraft that require a narrow engine package. The low profile slant version places the engine at 70 degrees from vertical to fit more conventional cowlings. Our low profile 70 degree slant version is internally designed from the factory to be mounted at an angle and this is not an aftermarket modification that may effect reliability.
All of our engines are assemble by us from all new parts. We never use any unknown JDM, used, "rebuilt", "on condition" or other junk yard parts by any name. Why buy a used engine when you can buy all new for less.
117 hp @ 5800 rpm (2320 prop rpm)
183 lbs dry weight
The AM15 is the cost effective alternative to the Lycoming O-235, Lycoming IO-233 and others. Like the AM13, the AM15 is a 16 valve, SOHC, inline 4 cylinder engine of aluminum construction and utilizes gear reduction to provide efficient power in a small light weight package. The AM15's fuel and ignition are controlled by a Bosch FADEC system for simplicity of operation and outstanding fuel economy. At economy 55% power cruise the fuel consumption is an ultra low 0.39 lbs/hp/hr providing a fuel flow of just 4.2 gal/hr! Add to this the ability to run on auto fuel and your fuel costs drop dramatically. Why suffer the high cost of a Lycoming, Rotax or Continental when the new choice is clear.
MessagePosté le: Sam 28 Juin - 00:16 (2014)    Sujet du message: Publicité
MessagePosté le: Sam 28 Juin - 08:53 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Bonjour Leonid,
Plus d'infos sur ce forum http://www.homebuiltairplanes.com/forums/general-auto-conversion-discussion…
MessagePosté le: Sam 28 Juin - 10:30 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Cela rappelle l'aventure Tielert avec le 1700 cc  de Mercedes. Savez vous dire sur quelle voiture est monté à l'origine le 1500 ? Une idée du TBO ?
MessagePosté le: Sam 28 Juin - 20:25 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Surement plus que ton moteur Russe Shocked
MessagePosté le: Dim 29 Juin - 01:29 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Plutôt l'inverse, car il est très probable que le futur de ce moteur, si merveilleux soit-il, n'arrive pas à la cheville du passé du Vendeneyev M14, qui débuta sa carrière un peu avant le second conflit mondial et toujours produit à l'heure actuelle (le seul radial certifié encore en production).
MessagePosté le: Dim 29 Juin - 08:34 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Ton moteur Russe a toi..
MessagePosté le: Dim 29 Juin - 09:34 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Moi je n'ai aucun moteur russe... Même si j'ai eu l'occasion de démarrer bien des fois un radial M14.
Mais encore une fois, une intervention hors sujet par rapport au post, pour parler d'un type et non de l'objet de ce post : Le moteur EAR M 13 ou M15...
Il y a un sujet dédié Xavier ! Tu peux te lâcher là bas...
MessagePosté le: Dim 29 Juin - 23:51 (2014)    Sujet du message: moteur AEROMOMENTUM AM-15 Répondre en citant
Tielert est GAZOIL - ils sont ~ +15-20kg (d'habitude) plus lourde que moteur d'essence, aussi Tielert est base sur moteur de l'ancien génération !
..aujourd'hui avec programme de "downsizing" en industrie de l'automobile, il existe très beaux moteurs de voitures avec beaucoup de puissance qui sommes legere (je personnellement conduis Nissan avec 1.6 turbo 200cv ...)
autre exemple http://www.vikingaircraftengines.com/ - ce engin déjà monter sur PLUSIEUR avion et gyrocopteres a USA (il est base sur plateforme de Honda moteur L15a - moteur utilise pour "racing"), je suis d'accord que il sont pas si bon comme ROTAX, mais...tendance...
PS: pour plus d'information sur technologie d'aujourd'hui sur les moteurs des voitures - regarde ici régulièrement http://www.enginetechnologyinternational.com/
MessagePosté le: Aujourd’hui à 22:50 (2018)    Sujet du message: moteur AEROMOMENTUM AM-15
