Accident autogire Magni M24 en CHARENTE (16)
Goto page: 1, 2  >
aerocopter
PostPosted: Tue 25 Aug - 18:25 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
Voici les premières informations sur cet accident s'étant produit avec un M24 en CHARENTE (16).
http://www.sudouest.fr/2011/08/22/le-pilote-de-l-autogire-reconnait-son-err…
PostPosted: Tue 25 Aug - 18:25 (2015)    Post subject: Publicité
Guest
PostPosted: Tue 25 Aug - 18:51 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
j'ai lu cela il y a un bon moment déjà,
là au moins le giro n'est pas en cause OOOUUUFFFF
PostPosted: Tue 25 Aug - 19:51 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
Pas sur. Avec un M16 914, ça aurait sûrement passé. Ça n empêche que le pilote n est pas clair sur ce coup la.
Guest
PostPosted: Tue 25 Aug - 20:05 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
le 24 est un des autogires qui a le moins de trainée
lis ce que jukka tervamaki vient d'écrire sur rotarywing en présentant son dernier programme de calcul de trainée
je sais pas si le 16 serait passé au dessus, dans tous les cas le pilote reconnait sa connerie
"The drag coefficient of the M24 is quite low, cd = 0.28 with the wheel fairings on. I do not have 3D models of many other gyro types but the Flow Design gave 0.36 for my own JT-5 model.
The problem of most pusher gyros is that the fuselage ends up abruptly due to the engine and propeller creating some turbulence. However, the smoothness of the front part of the fuselage is far more important as is the number and size of protrusions like landing gear, rotor mast, control rods, air intake openings, cooling radiators, the size of tail surfaces, etc. Fairings help to reduce the drag.
For the two tractor configurations I have a model the Flow Design gave a cd of 0.36 for my own JT-9 model and 0.54 for the Pittbull model. The latter one has an open cockpit and a some big protrusions.
It should be noted that the fuselage drag is only part of the total drag, the other components are rotor profile drag and rotor induced drag.
The one gyro which looks like a very low drag design to me is the Bulgarian NIKI Aviation Lightning. The designers do not emphasize low drag but ”The position of the tail makes the machine look more elegant and futuristic”. This is true.
http://www.nikiaviation.com/en/models/lightning/specs"
PostPosted: Tue 25 Aug - 20:06 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
Voilà dans ce cas J.Michel devrait nous donner son avis, car plusieures infractions sont sans fondement, dont:
1- Il n'est pas interdit de décoller de son champ.
2- le port du casque n'est pas obligatoire.
Pour le reste on ne sais pas ... mais c'est grave si des enqueteurs ne connaisse pas la loi.
Guest
PostPosted: Tue 25 Aug - 20:10 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
le principal crime commis c'est qu'il a cassé son 24 au lieu de me le donner !
PostPosted: Tue 25 Aug - 22:41 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
22 Août 2011... Soit il y a 4 ans...
PostPosted: Tue 25 Aug - 23:21 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
C est du réchauffé!!! Bien vu GMA
PostPosted: Wed 26 Aug - 05:19 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
Oups !! effectvement c'est vieux.  Okay
PostPosted: Wed 26 Aug - 07:18 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
Moins vieux, (décembre 2014)  je ne sais plus si on en a parlé sur le forum :
http://www.lavoixdunord.fr/region/bailleul-un-ulm-s-ecrase-a-cote-de-l-a25-deux-blesses-ia18b0n2550387
Et là encore ligne ou pas ligne ?
Guest
PostPosted: Wed 26 Aug - 07:46 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
finalement je vais garder ma barre qui va de la tête de rotor à l'avant de mon ventillateur, ca m'évitera la décapitation
PostPosted: Wed 26 Aug - 08:10 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
bon même avec du retard, les pare brise en plexi glace on l avantage de s ouvrir en cas de choque a l inverse du polycarbonate qui peut t emprisonner dans la carlingue mais a chaque fois les passager se font des coupuresrien ne vaut un autogire ouvert !
Visit poster’s website MSN
Guest
PostPosted: Wed 26 Aug - 09:08 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
oui mais là aussi il faut faire attention ...
petite anecdote , je me penche dans le cockpit de ma trapanelle à rotor pour changer des trucs sur les pédales de palonnier et je me gratte le front sur le pléxiglass de mon pare-brise, et je fais le boulot , en relevant la tête ça me brule un peu, je regarde le bord du pare-brise et je vois une substance marron ... de la peau bien entendu ... le bord du plexi était tranchant ! Kamal mon pote tordu de rire , je t'avais proposé du liston (rebord en caoutchouc)  et tu l'as pas mis ...
depuis je j'ai mis (je n'en avais mis qu'en haut pour pas demander une trop grande longueur a kamal a qui j'avais piqué une chute)
comme quoi en terme de sécurité passive il ne faut rien négliger, ou en négliger le mois possible
le plexiglass coupé ou cassé est tranchant comme un lame de rasoir et cas de choc c'est le le cou tranché ...
PostPosted: Wed 26 Aug - 16:58 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
... D'où le sketch... "tout condamné à mort aura la têteu trannnchéééeeeee"...
Guest
PostPosted: Wed 26 Aug - 18:40 (2015)    Post subject: Accident autogire Magni M24 en CHARENTE (16) Reply with quote
retrospectivement en effet cela fout les jetons ..... imagine je tape de face et je m'égorge .... bon remarquez comme çà ca ferait des vacances à certains hahahahaha
Goto page: 1, 2  >
Page 1 of 2
Index | Create own nforum | Free support forum | Free forums directory | Report a violation | Cookies | Charte | Conditions générales d'utilisation
